Can anyone help me in getting ICL7662CBA+ module/library for fritzing software?
Thanks!
Thanks!
It appears you would need to provide a web site with exactly what you want since a google search for “ICL7662CBA+ module” doesn’t turn up anything useful.
Thanks Peter:
Here is the part/module I am looking for in fritzing?
https://www.digikey.com/en/products/detail/analog-devices-inc-maxim-integrated/ICL7662CBA/1303153
Thanks,
Kokeb
Easiest is going to be make your own from a generic IC like this:
first drag a generic IC in to the sketch
then
select edit pin labels (which requires the chip be in a sketch)
then add the labels for the pins and save it.
If you need an smd part change the package type in Inspector (the lower right window.)
Thank you Peter for your cooperation!
Ehm?! There is a premade ICL7662 in the voltage regulators bin, with a properly designed schematic symbol for it. There is a part both for the DIP package and one for the SOIC package.
The ICL 7662 is an industry standard voltage doubler that is made by a large number of manufacturers. Some manufacturers also make improved versions of it, such as the Microchip MCP1252, you can also use the part for those.
