Can not find ICL7660 negative voltage supply?
There doesn’t appear to be one (although I seem to recall making one at some point a search didn’t find one.) Since it appears to be an 8 pin dip, you can use a generic IC and change the pin labels to make a part.
I did it, thank you. I used a generic IC with 8 pins, as you said.
