Does anyone have a design for an 8 channel relay board with an I2C interface with selectable I2C address?
I would have thought this was common place but I can’t seem to find any designs.
Chris
Chris
A google search for “fritzing part i2c 8 channel relay board” turns up
https://fritzing.org/projects/8-channle-relay-modul-controllplatine
if you are looking to make one from components. A google search for “i2c 8 channel relay board” turns up a bunch of modules (which may or may not have Fritzing parts) if you are looking for a prebuilt module.
Hi chomski99,
yes, i have find the same on the fritzing website as vanepp has find.
But normaly, this is not really very difficould. You should design an self-one.
Bey, Jürgen B., from Germany
Hi Everyone
The part referenced in the project has only pin headers. Pls use
8-channel Power Relay-fixed.fzpz (110.8 KB)
