I need the component file (. Fzb file) of photosensitive sensor and DS1302 and infrared remote controller. I hope someone can give me.Thanks!
Typically a reference to the data sheet for the part you want is the right place to start. There are ldr type parts (photo sensitive resistor) in core parts, but that may not be what you want. There is a ds1302 chip in core parts but not a module (which I assume is what you want.) A google search for “fritzing part ds1302 module” turns up several if one of them matches what you have and works correctly, problem solved. The IR remote controller typically doen’t connect except via IR so there is unlikely to be a Fritzing part for it although there are some hits in a google search for it.
