So i have a school assignment where i need to connect schemes physically on the experiment board. I have this scheme and i cant find the way of inserting it in fritzing so i can see how it needs to be connected on the board. If someone can help and maybe build this scheme because i also dont know how to use the apk
You find the parts either in core parts or on the net, move them in to the sketch and then connect the pins in either breadboard or schematic (it sounds like you have a schematic so that is likely the place to start) and then Fritizng will create connections to the parts in breadboard and pcb. It is relatively simple. If you run in to problems upload the sketch file (the .fzz file) here and we will look it over and make suggestions.
