Hello, I’m a newbie. Can anyone help me with GY-906 sensor in fritzing?
I need help with GY-906 sensor
This should do what you need. As usual the mounting holes in pcb are only in silkscreen, if you want the mounting holes drilled you need to drag a hole over the circles in silkscreen to drill the hole.
gy-906.fzpz (5.0 KB)
