Can someone please make me a custom pcb shape
The measurements are in cm
The first image doesn’t have enough information. The measurements between all of the red lines would be required to make the shape wanted.
here is the svg for the second shape (which is fully defined.) Appears to load correctly on Fritzing 0.9.9, but may have problems on earlier Fritzing versions due to bugs in gerber path processing.
right click on the image and select “Save image as” to get the svg downloaded, then in pcb view with the pcb selected click on load image file and select the downloaded svg to load the shape. In the gerber export the contour.gm1 file should have the shape like this (displayed in gerbv)
