I need help. Looking for Lolin D32 pro parts.
Hello! I’m looking for Lolin D32
pro parts, but they don’t come up when I search, so I need help! I appreciate it.
This part should do what you want. Note the mounting holes in pcb are not drilled by default, if you want mounting holes drilled you need to drag the hole from core parts/pcb/ hole in to the sketch, place it over the hole in silkscreen and set the size appropriately. The connectors (I2C, bat and tft) are not reflected in pcb as they can’t be connected to in pcb (they are available in breadboard and schematic.) I also just realized this isn’t the board you asked for but rather the Wemos Lolin D32-PRO V2.0 which is the latest board.
wemos-D32-pro.fzpz (26.9 KB)
This appears to be an earlier board without the I2C or tftp connectors (or the second jpeg is wrong, as the first appears to be the current V2.0 version) If you really want the V1.o version I’ll have to see if they still have documentation for it.
