I need help about how to make a Pitot tube
Halo. I need a pitot tube in my scheme and I don’t know how to make it in the program, I’m new here.
For example like this
I only need a pitot tube
We would need a data sheet with physical dimensions and connections (which are likely air rather than electrical) for the device you want.
edit
There also doesn’t appear to be a Fritzing part for the mpxv6002dp shown in your image, it would also need a data sheet with physical dimensions and electrical connections if you want a part.
Yes exactly!
The template is there for a very good reason…
Thanks for the answer. I found the other components. I sent the picture only as an example, I use some slightly different components, but the pitot tube is similar. I will put a link that explains the pitot tube because I can’t find the datasheet anywhere. If you manage to do it, thank you very much, if not, thank you, because I can find a lot of good things on the forum. Here is a link Pitot - Static Tube - Speedometer | Glenn Research Center | NASA
Ah, so it is a n airway connection
Now the mpxv6002dp module. We need the data sheet of that part
I use MPXV5100DP.
Look at page 13 and 14.
Thanks
If it eaiser you can create this mpxv MPXV4006 datasheet(7/22 Pages) FREESCALE | Integrated Silicon Pressure Sensor On-Chip Signal Conditioned, Temperature Compensated and Calibrated insted mpxv5100DP.
Whichever is easier for You (You don’t need both, just whichever is easier for you)
Anyway for the breakout board
There isn’t enough information on the web (i.e. board dimensions) to make a part…
Can you check here. If it can’t be created, no problem, thank you for your efforts.
MPXV4006DP datasheet(7/12 Pages) MOTOROLA | INTEGRATED PRESSURE SENSOR at slide 7.
No, this is not the module…
I’ll try my best to dig⛏️ out more info…
I’ve dug the web but my efforts are still futile (mark my words, my “Googling” skills are quite bad…)
OK, since the tube is not an electrical part, I just inserted it into the sketch like this:
pitot tube fritzing.fzz (57.5 KB)
Thank you very much.
If I manage to find anything, I will send it.
Thanks again for the pitot tube
@ante198567 You got lucky, I’ve found a website that shows physical dimensions.
Here is the part you want
MPXV7002DP Pressure Sensor.fzpz (38.8 KB)
with the example sketch here
pitot tube w Arduino.fzz (98.7 KB)
OK, I just realised that breadboard images will get lost in SVG export. @vanepp do you think it would be a vaild enhancement request to have bitmap images in SVG during export?
While you would need to ask the developers, I expect it may be difficult if not impossible to include a bitmap image in an svg. Bitmaps are not scalable (although you can insert images in an svg) and thus won’t scale well. Your best bet would be to make the pitot tube a path which is scalable I expect.
