I need fzpz of module LM317 2A Voltage Reduction Circuit
Does anyone have fzpz of module LM317 2A Voltage Reduction Circuit (The picture under). Thank!
Insufficient information to do anything with. You need to fill in the template that you appear to have ignored with a web site with the physical dimensions and connection information of the part. Pictures are basically useless. A google search of the form “fritzing part LM317 2A Voltage Reduction Circuit” (which is the best way to find existing parts) indicates there likely isn’t currently anything suitable so a new part would need to be made but there isn’t enough information here to do that (which is why the template is here.)
You got lucky, I needed an example part for the template and used yours. This part should do what you want.
lm317-module.fzpz (8.8 KB)
