I need an APDS-9930 proxim sensor and a KS0320 Module part file
Peeps, I am not very good at this whole Fritzing thing and I NEED the exact part in Fritzing because it’s for a research paper and the Fritzing build and schematic need to be as close to the actual parts that I have and will be using for my module, because this is for academic research.
A) APDS-9930:
A1) I have checked, at least, 4 GitHub repos for any file the has “APDS-9930” in the search terms, and have not found one.
A2) It’s a 6 pin, small, ambient light and proximity sensor. I need the exact Fritzing part file though so that I can download a copy to a research paper.
B) KS0320:
B1) I have looked in like 30 different places for any file even remotely matching the KS0320 Electromagnet module, and it’s like it just doesn’t exist.
B2) The KS0320 is a 4 pin module from KEYESTUDIO.
I know that I was supposed to provide a copy of the data/stats sheet for these, but I couldn’t find one that looked right and wasn’t an assortment of slides or a website. You also apparently can’t link a pdf to a forum topic, which is kinda silly to be honest.
I really don’t have the skills, nor time to learn them, to do this on my own. I have little to give spare my own appreciation, but I really need help. Please.
A google search of the form “fritzing part APDS-9930” turns up APDS-9930 (I have no idea what the difference is!) If that won’t do we would need a web site with the physical dimensions (as called for in the template in this category!) to make a part (which will take a while as there is a line of requests at the moment.) Same applies to the KS0320.
