I couldn’t find MIKROE-4111mux.
Please I need your help.
Not enough information here to do anything with. The template in this category tells you what is needed, essentially a web site that describes what you want with physical dimensions and connection information. Without that nothing can be done.
No, no dimensional information to know what the size of the thing is. It details the connections but that isn’t enough to make a part.
Thank you Peter. The dimensions of the MIKROE-4111:
Length: 57.15 mm
Width:25.4 mm
It is something similar to this one.
Even if I can have it without exact dimensions, it is fine.
That should be enough to make a part. I’ll post it when it is finished.
This part should do what you want. Pcb view has been suppressed as not useful.
Mikroe-MIK4111mux.fzpz (11.3 KB)
Thank you Peter, I appreciate your help
