Check the size of the sketch file (the .fzz file.) It is likely 0 and thus doesn’t exist which is the typical reason for this error. For some reason Fritzing can’t write in to the desktop (likely because of OneDrive which has caused problems in the past) so the first thing to try is to save the sketch to somewhere local to your machine’s drive (i.e. not on OneDrive) and see if that works. Assuming that works you have a problem with OneDrive which you need to fix.
I haven’t saved it on One Drive, actually I am turning the synchronization off, I saved the file into the desktop so it shouldn’t be the problem I guess.
which as noted has caused problems in the past. Check the size of the file above, it is likely 0 in which case the sketch won’t open. Try saving the file to somewhere on you C: drive where you can write (assuming you have something writable in your C: drive) as that should work (as technically should OneDrive but as noted there have been past problems with OneDrive not working correctly.)
C:/Users/ana-a/Untitled Sketch 2.fzz
and verify that works (which will indicate a OneDrive problem.) If that doesn’t work you appear to have another type of permission problem as it appears the sketch file can’t be successfully written and then read by Fritzing.
I checked the size of the file, actually it’s not 0, the size is 5.71KB and 8KB on disk.
In that case since it’s not 0 is there a possible way to make it work and be able to open that file?
If you upload the .fzz file (upload is 7th icon form the left in the reply menu) I can have a look at it and see if it is recoverable (and try it on Fritzing here to see what happens.) The error usually means that the .fzz file (which is a zip file) is corrupted and thus not recoverable, but it may be with some work or there may be a problem with your install and the .fzz is fine.
which says there is something wrong with your installation. Things to try are reinstall Fritzing after clearing the user directories (although that hasn’t been much of a problem in recent years it is still probably worth trying!) here are the instructions for clearing the user directories (note this will delete all your custom parts so save them as .fzpz files so you can restore them or move the directories aside)
Try shutting down OneDrive if you can easily before doing the install may also help. As noted I think OneDrive usually works (I don’t use it, so I don’t know!) but there have been some issues in the past. It appears something on your system is causing the .fzz file to be not readable although the uploaded file is readable here, so the file looks OK, just something on your system has a problem. You might want to try unzipping the .fzz file (I use 7zip but any unzip program should work) the unzipped file should look like this
I deleted the program and redownloaded it again, but the main step was as you mentioned is to save it somewhere else outside of that OneDrive. I tried making a new one and save it somewhere else than OneDrive and they were working 100%.
I suspect there was/is a permissions problem with the OneDrive files, but I don’t know where or how to fix it. As long as you have a solution that works for you, things are good.
