Dear FritzingUsers,
I bought HT1621 LCD Display Module and need part library for fritzing. please refer below link for Display details.
Can anybody has part library for the same.
Please help.
Thanks
Dear FritzingUsers,
Please help.
Thanks
This should do what you want. As always before ordering boards print out the pcb footprint at 1:1 scale and check it against an actual board. As well if you want mounting holes drilled you need to drag a hole from the pcb section of core parts over the hole in silkscreen because by default the mounting holes are not drilled.
HT1621-LCD-Display-Module.fzpz (7.8 KB)
