how can I fill in the blanks of the PCB?
Not sure what you mean by this, can you provide a screenshot?
Ah! Click on Routing and then Ground Fill.
perfect !!!
I am not able to understand your question. Can you please tell me about which empty spaces you people are discussing.
I am also a PCB designer and always found some problems during its fabrication.
Please describe your problem so that i could also get the idea about it.
all right. solved: Click on Routing and then Ground Fill
I think you should make your design type more compact:joy_cat:
