Probably somebody already asked, but how do you export an image with more white space around? The exprot as png or jpg is really cut sharply around the composants.
Two suggestions off the top of my head: add an image (visible here, but it should be able to be an svg with an invisible drawing element) via the load image file in core parts/ breadboard to increase the bounding box size.
or (more work) export the images as svg and edit the bounding box in Inkscape or another svg editor.
Same idea, but export as png, and use gimp (or other image editor) to add the desired border.
