How can I set multicolored wires like the ones in the attached image? I have seen this in dozens of the hookup guides and tutorials. My project uses both 3.3V and 5V this red/white striped wire would help a lot.
When you select the wire, in the Inspector (right bottom of window) check the “Banded” check box next to the drop down for the wire color.
YESSS!!! Thank you so much!!!
Happy I could help.
