Instead straight line I want curved line for wires.
Please help me.
Left click on the wire, hold down the cntrl key and drag the wire. It will be curved rather than straight.
That is by default. There is a per view checkbox configuration setting that controls how it works. To change it, select “Preferences” from the “Edit” menu, then the different view tabs.
When you mouse-down and drag on a wire or the leg of a part (as opposed to a connector or a bendpoint) do you want to change the curvature of the wire (or leg) or drag out a new bendpoint?
This checkbox sets the default behavior. You can switch back to the non-default behavior by holding down the Control key (Mac: Command key) when you drag.
So drag does one thing, control+drag the other, and the checkbox determines which is which.
