In the following circuit, how to fill the number of the two resistors?
You can use a potentiometer to make Vout adjustable or you can calculate both R1 and R2 to make Vout fixed.
In case you want to make it fixed: What voltage do you have in Vin and what voltage do you require in Vout?
