How do I stack wave share Hats to Pi in Diagrams?
Hello everyone,
How would I stack waveshare HATs onto the Raspberry Pi in the hardware diagram? I tried doing it but could not figure it out. They just overlap one another and no connections show up. Thanks for any feedback and support!
It depends on how the parts are set. One needs to have female pins and the other male to connect. If they don’t you won’t get a connection in which case you need to run a wire from the hat to the RPI board. Uploading the the sketch (the .fzz file, upload is 7th icon from the left in the reply menu) would give us more information.
I assume by hardware diagram you mean breadboard view.
If they won’t connect on their own by just dragging, you can temporarily position them offset from each other, run wires between all of the corresponding pins, then move the one back on top of the other. Once aligned, the wires become zero length, but the connections now exist.
