How do I shrink this part in schematic view?
I imported a tpic6b595 from a Github Repository, and it was unsually large when I opened it in schematic. Is there a way to make it smaller?
I’m new to Fritzing, and I have not touched upon the parts creation component of Fritzing. I just need the tpic6b595 be smaller in schematic.
TPIC6B595.fzpz (10.0 KB)
The <svg> entry at the top of the SVG should contain a viewbox , a width, and a height entry. Width and height should be in absolute dimensions, for example mm or in.
Adobe tools often remove these.
To re-size correctly, the connector lines can be used as orentation, they should be 100mil (1/10 inch, 2.54mm) long.
Another option to use the generic dip v2 instead. You will have to enter the 20 connectors names and the part name, and should get a nice schematic and 20 pin DIP.
Thank you very much! I will use the generic dip v2, as you have suggested.
