Hello,How I can resize the canva in the İnkspace ?
I’m not sure I understand the question. You can draw as large as you want by default, when you are done you need to do Edit->Select All then Edit->Resize page to selection. That will resize the view box to the elements of the drawing and reset the starting point to 0 0.
