Anybody using this part? I’ll appreciate if you could share the .fzpz part please. Here you are some info if needed (Please note model c is not equal to the LD2410 already posted in the forums)
This part should do what you want. Check the pins match the printing on the board though, I think they are correct but it needed a swap in the images on their web site and thus may be backwards.
Hi-link-HLK-LD2410C.fzpz (10.0 KB)
Thank you Peter! I’ll take a look and come back if some pinout is not clear.
Hi Peter. I posted this on the wrong thread earlier. I meant to post the question here for the LD2410C.
I am looking for a un-mirrored (component side) version of the pins though. Like the version HLK site linked above. This part looks at the bottom as if it would be mounted on the copper side of the board with the pins facing you. I am using breadboard layout because I am using strip board. The board image would also be the other side, but does not matter. I have googled, but only found this page. Please let me know if there is another part as described above out there.
OK so you want breadboard to look like this:
rather than like this
(where tx is on the right) is that correct?
Hi Peter. That is 100% correct. Tx is on the right in bottom (solder side) view as shown by your tool-tip.
Tx is on the left in the fist image (component side) as shown on the silk screen in image.
So the fist image with TX on the left is what I am looking for.
I also managed to post the new part in the wrong thread. I’ll remove the old part from the other thread in a minute, but here is the part with the pin numbering correct.
Hi-link-HLK-LD2410C-bb-reversed.fzpz (11.1 KB)
This part has probably the intended (according to the datasheet) pin numbering.
Perfect. Thank you Peter.
