hi bros and sis, im looking for this fritzing part
https://www.hlktech.net/index.php?id=988
thanks in advance !!
thanks bro is really good piece of art ![]()
Thank you, I have been looking for this exact part. I am looking for a mirrored version of the pins though. Like the version HLK site linked above. This part looks at the bottom as if it would be mounted on the copper side of the board with the pins facing you. I am using breadboard layout because I am using strip board. The board image would also be the other side, but does not matter. I have googled, but only found this page. Please let me know if there is another part as described above out there.
Hi Peter, Thank you for your response. My humblest apologies. I just realized that I posted this on the wrong thread. I meant to post it on the HLK-LD2410C thread. (I had both tabs open and went back to the wrong one (facepalm) )
OK, I deleted the part because it wasn’t correct any way (needs to flip in both h and V to be correct I think.) I’ll do the part you want.
Thanks, Sorry that I wasted your time.
This part should do what you want. Comparing it to a real board is advised though to make sure it is correct!
This was in the wrong thread, it should have been posted here
in the thread for the correct part (this is a different but similar part!) and was moved there to keep both versions together.
Hi Peter, Thank you. This part is perfect for what I need.
The pin numbers is the the only thing that must change (Not names). Pin 1 is on Tx. This may only be confusing on PCB layout with the square pad on pin 5.
I think you also made the mistake I did. I think that this thread is for HLK-LD2410B and not the HLK-LD2410C
I can reassign the pin numbers in the parts editor with the set graphic button, but don’t know how to change the number text next to the pin in the Schematic view. I also played with that niggly square pad on the PCB view, but screwed up everything when I tried to drag the pad.
