No, and to make a part we would need more information such as a web site with mechanical data such as dimensions and connection information (although I assume the single red connects to the two reds and the single blue to the two blues. So mostly size information is needed and probably a more straight on picture.)
edit: found it via a google search, will make a part.
edit2:
Here is a part that should do what you want. Pcb consists of only the silkscreen outline of the part as the wires connect to the connector not the pcb.
Connector-2-In-4-out.fzpz (4.9 KB)
edit (Jan 30 2023) added 2-in-8-out part
Connector-2in-8-out.fzpz (5.8 KB)
