Hello, I need help with creating W6100-EVB-Pico parts. I’m still having trouble with the parts editor. I tried to edit it on an existing RaspberrIPi Pico part, but it didn’t work. The documentation for the part is here: W6100-EVB-Pico | WIZnet Document System
Thank you for your willingness
This part should do what you want. Of note, as usual the mounting holes in pcb are not drilled by default. If you want mounting holes in your sketch you need to drag the core parts->pcb->hole icon in to the sketch, place it over the mounting hole on silkscreen and set the size appropriately.
