PLEASE help me with breakout of MiCS-VZ-89TE, MQ-136 sensors and CH340E
Not enough information here to do anything with. In general a google search of the form “fritzing part MiCS-VZ-89TE” is a good place to start. In this case it doesn’t find a part, but indicates both the part and at least one module using the part is available. As a result we would need a web site for the exact thing you want with connections all documented and physical dimensions (what the template that you appear to have ignored asks for basically.)
ok Thanks I will send your informations and datasheets
The MQ136 will work with this part (the pinouts are identical
https://forum.fritzing.org/t/mq-4-sensor-part/6035/9fritzing part ch340
The (or at least a) ch340 chip is available here (from a google search for “fritzing part ch340”
if you need a different package one can be made from the generic IC. The MiCS-VZ-89TE needs a new part which will be up in a while.
Ok thanks for everything
I’m New here i need your help please
This part should do what you want for the MiCS-VZ-89TE. As usual if you want the mounting holes drilled in pcb you need to drag a hole from core parts/pcb/hole in the sketch place it over the mounting hole on silkscreen and then set the appropriate size.
MiCS-VZ-89TE.fzpz (23.4 KB)
What other help do you need?
