Hi everyone,
I’ve just finished creating a part for the GGreg20_V3 Ionizing radiation detector (Geiger counter) by IoT-devices. This is my first time creating a complex part with custom PCB and Breadboard views, and I’m sure there are some technical issues under the hood (SVG scaling, terminal points, or XML structure).
The module has 4 pins (BAT-, BAT+, GND, OUT). I’ve tried to follow the copper1 → copper0 hierarchy for the PCB view and used a black rectangle for the silk mask.
Could someone please run this through the FritzingCheckPart script and check if the connectors are properly aligned and the SVG code is clean?
Any feedback or “fixed” version of the file would be greatly appreciated! If possible, could you please provide a corrected .fzpz file with the necessary fixes, as I’m still learning the technical requirements?
Best Regrds,
Oleksii Yanko
co-founder
IoT-devices LLC
Kyiv, Ukraine
Name of the part❗
GGreg20_V3 - DIY Geiger counter module
- I’ve created part by my own. See below.
Top view❗
The part file to check:
IoT-devices GGreg20_V3 Geiger counter.fzpz (39.4 KB)
Datasheet❗
As a new forum user, I am unable to add multiple images. I am also unable to add a link to the module description, but it almost exactly matches the Datasheet PDF. Therefore, please write to me and I will provide the necessary additional information.
Does not apply to breakout boards.
