I’m trying to locate within Fritzing the file PCBViewGraphic_Template.svg. I know it is in the fonts and templates folder but have not been able to find such folder within the fritzing subdirectories. I have version 0.9.2. I’m trying to modify the PCB View for HEADER 4 in the connectors library by first loading the PCBViewGraphic_Template.svg file. Any help is much appreciated. Wish it was much easier to just modify the distance between pins in one of the PCB Views. This process is not very intuitive although I am a beginner to fritzing. Seems that if the part isn’t included in the fritzing libraries or bins you are kind of out of luck unless you want to go through a quite long and arduous learning curve.
