Hi everyone! I’m hoping someone can help me with a project I’m working on. I’m trying to build a circuit that uses a Light Dependent Resistor (LDR) to control the speed of a DC motor, but I’m having some difficulties understanding how to properly assemble it. I’ve looked at some tutorials online, but I’m still confused about the correct wiring.
Components I’m using:
- LDR (Light Dependent Resistor) sensor
- Resistors: 10k x2 and 330 Ohm x1
- LED (Light Emitting Diode)
- Breadboard
- LM358 IC (Integrated Circuit - Operational Amplifier)
- 7404 IC (Hex Inverter)
- IRFZ44N MOSFET (Metal-Oxide-Semiconductor Field-Effect Transistor)
- 1N4007 Diode
- 6V/12V DC Motor
- 5K Potentiometer
I have the schematic attached below that I’m trying to follow, but I’m having trouble understanding:
Here is my project file with the components already added:
LDR_DC_MOTOR.fzz (17.2 KB)
If someone could please help me with the correct wiring configuration and possibly share an updated project file, I would be incredibly grateful!
Thank you in advance for any help you can provide! ![]()
