Hello! I tried to follow the Adafruit tutorial in converting .brd files into fzpz, however, I’m stuck at using the QT Creator and can’t seem to build it.
Can someone who knows how to convert lend me hand? I really need this asap.
Thanks!
Thanks!
This part should do what you want. Note the Qwiik connectors don’t appear on pcb and the mounting holes are not drilled (if you want mounting holes drilled you need to drag a hole in to your sketch from core parts pcb/hole and set the size correctly and over lay it on the circle in silkscreen.)
sparkfun-SAM-M10Q.fzpz (9.8 KB)
Thank youuuuuuuuuuuuu so much!
