Hello im new to fritzing, Can someone help me i cant find 5 channel TCRT5000 Tracking Sensor
here is the link
5 Ways TCRT5000 Tracking Sensor Module Tutorial : 4 Steps - Instructables
A google search of the form “fritzing part 5 channel tcrt5000 tracking sensor” turns up this post
which may or may not do what you want.
i am using it for my sumobot / line tracking project, the one you suggested is for flame detector
the one im looking for is Reflective Optical Sensor that is look exactly in the provided image
Then you need to provide a web site that specifies the mechanical data (such as size) and the connections. There likely isn’t currently a part for this and one would need to be made. Images are not much use for anything.
Hello Peter,
It turns out that I am looking for this part that seems no one has made yet. It is something common for line-following cars. I am leaving you the dimensions and schematics to see if the component could be made. I think it would be fine whether it is viewed from above or below, whichever is easier. Thank you in advance, and I wouldn’t know how to repay the excellent work you do for the Fritzing user community.
5channel-TCRT5000-line-tracker.fzpz (7.5 KB)
