felic
January 4, 2025, 3:47pm
1
H11L1
Previous work, similar parts
https://www.alldatasheet.com/datasheet-pdf/view/3041/MOTOROLA/H11L1.html
IC
6-Pin DIP
STANDARD THRU HOLE CASE 730A–04
vanepp
January 4, 2025, 4:07pm
2
A google search of the form “fritzing part optocoupler” turns up this part which may do what you want. If not the generic IC part will let you make yourself a part.
Welcome aboard! Your part has a number of problems, mostly in schematic and pcb. In schematic
[capture]
You are lacking valid terminalIds which cause the wires to connect to the center of the pin rather than the end as they should. Then pin 2 is not on the .1in grid as it should be, the three pins should be .1in apart so they fit on the grid correctly. As well you appear to have a bus that should not be present. If I click on pin2
[capture1]
pin5 lights up as well indicating Fritzing think…
