I was looking for cables and kind of like the Grove connectors and cables. Is this something is available in the parts bin? I didn’t see anything under cable(s). I see Seeed have them as well as SDL.
Hi, I can’t find a Grove cable. Therefore, do I to wire each one “manually” or the is a part for it?
Thanks
Fritzng doesn’t support cables so yes you have to use 3 or 4 wires (depending on the grove connector) to wire them.
