Grove - 2-Channel Inductive Sensor (LDC1612)
Hi, I need help converting some eagle files and creating the Grove - 2-Channel Inductive Sensor (LDC1612) part.
(I’m having difficulties installing Qt, so I can’t run eagle2fritzing!)
Eagle Files
This part should do what you want. Note the grove connector doesn’t appear on pcb and by default the mounting holes are not drilled. If you want mounting holes you need to drag a hole from core parts/pcb in to the sketch place it over the circle in silkscreen and then set the size appropriately.
seeedstudio-LDC1612.fzpz (11.9 KB)
