I am new to fritzing and not sure how to create a part whilst being on a tight deadline. Just want to ask if anyone has made the Grove - 2.5A DC Current
Sensor (ACS70331).
The data sheet is: 3759106.pdf (farnell.com)
If anyone could make one or has a part, it would be of great help.
Thanks
This should do what you want. Note there is no pcb as it is not useful (use a 4 pin 0.1in or 2mm header if you need pcb!) Also I couldn’t find any dimensions online so the part was created from a scaled jpg image and thus may not be mechanically accurate (but without pcb that doesn’t really matter either …)
