Grove - 1 Channel Relay Module
hello, can anyone help finding this part. It’s a 1-channel relay module, operates in 3.3V-5V. need also to be able to use the terminal block
Dimensions: 42mm x 24mm x 18.5mm
I found a component where the terminal block isn’t connected. But I can fix that.
Would it be enough if I do it tomorrow? Maybe you can manage it yourself. I’ll attach the part here.
Groove_Relay.fzpz (11.7 KB)
Regards, Harald!
