Good day! I need help making a part for a GRBLDuino Limit Switch Isolator,
Info and drawing found here: https://shop.eccentricworkshop.com/wp-content/uploads/2019/01/GRBLDuino-Limit-Switch-Isolator-Datasheet.pdf
CIDRAM
Thank you!!
CIDRAM
Thank you!!
This should do what you want. Note pcb is a bit odd as the connections are screw terminals and would require a wire from the board to the terminal so there are pads outside the pcb border for the wires (I expect no one much will use pcb and it could be deleted!)
GRBLDuino-Limit-Switch-Isolator.fzpz (15.4 KB)
That’s so perfect! That should be the last piece I need to finish my project!
Thank you very much!!
