Fritzing Will Not Open - MacOS Ventura
I recently downgraded from Mac OS Sonoma to Ventura. Now fritzing will not open. I bought another copy and downloaded it and installed fresh, but am still getting this error:
Translated Report (Full Report Below)
Incident Identifier: 97C17688-BE80-4773-976D-44202B4B4B8E
CrashReporter Key: 9A0825E9-DE47-6FA4-CAC0-198185AEBC25
Hardware Model: MacBookPro18,1
Process: Fritzing [1568]
Path: /Applications/Fritzing.app/Contents/MacOS/Fritzing
Identifier: org.fritzing.Fritzing
Version: 1.0.0 (353be4)
Code Type: X86-64 (Native)
Role: Background
Parent Process: launchd [1]
Coalition: org.fritzing.Fritzing [1318]
Date/Time: 2023-11-06 11:29:09.0748 -0800
Launch Time: 2023-11-06 11:29:05.9524 -0800
OS Version: macOS 13.6.1 (22G313)
Release Type: User
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: ROSETTA 0
Triggered by Thread: 0
Thread 0 Crashed:
0 runtime 0x7ff7fff16544 0x7ff7fff12000 + 17732
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000022 x1: 0x0000000000000000 x2: 0x00007ff7fff43311 x3: 0x0000000000000800
x4: 0x00007ff7fff3e40e x5: 0x0000000000000000 x6: 0x000000000000002c x7: 0x0000000000000000
x8: 0x00007ff7fff4d000 x9: 0x0000000000000000 x10: 0x00000000fffffed4 x11: 0x0000000000000010
x12: 0x0000000000000078 x13: 0x000000000000001e x14: 0x00007ff7fff35980 x15: 0x00007ff7fff4d8b4
x16: 0x0000000000000209 x17: 0x000000030a779ae7 x18: 0x000000030a77a0ab x19: 0x00007ff7fff43311
x20: 0x00007ff7fff43311 x21: 0x0000000000000063 x22: 0x00007ff7fff3dddf x23: 0x000000030a779c10
x24: 0x000000010c2d02e0 x25: 0x0000000000000248 x26: 0x0000000000000009 x27: 0x0000000203b14000
x28: 0x0000000000000001 fp: 0x000000030a779ba0 lr: 0x00007ff7fff2fc18
sp: 0x000000030a779b80 pc: 0x00007ff7fff16544 cpsr: 0x40001000
far: 0x0000000000000000 esr: 0x56000080 Address size fault
Binary Images:
0x203a6c000 - 0x203b07fff dyld () <3df96f32-b9c9-3566-a6b7-4daebc6d6563> /usr/lib/dyld
0x7ff7fff12000 - 0x7ff7fff41fff runtime (
) <15ccd9bf-9a15-3540-a1ff-3abea3e2ca9d> /usr/libexec/rosetta/runtime
Error Formulating Crash Report:
dyld_process_snapshot_get_shared_cache failed
EOF
Full Report
{“app_name”:“Fritzing”,“timestamp”:“2023-11-06 11:29:09.00 -0800”,“app_version”:“1.0.0”,“slice_uuid”:“78f648a4-85e7-3af1-bcdd-8d594c00d837”,“build_version”:“353be4”,“platform”:0,“bundleID”:“org.fritzing.Fritzing”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 13.6.1 (22G313)”,“roots_installed”:0,“name”:“Fritzing”,“incident_id”:“97C17688-BE80-4773-976D-44202B4B4B8E”}
“uptime” : 380,
“procRole” : “Background”,
“version” : 2,
“userID” : 504,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,1”,
“coalitionID” : 1318,
“osVersion” : {
“train” : “macOS 13.6.1”,
“build” : “22G313”,
“releaseType” : “User”
“captureTime” : “2023-11-06 11:29:09.0748 -0800”,
“incident” : “97C17688-BE80-4773-976D-44202B4B4B8E”,
“pid” : 1568,
“translated” : true,
“cpuType” : “X86-64”,
“roots_installed” : 0,
“bug_type” : “309”,
“procLaunch” : “2023-11-06 11:29:05.9524 -0800”,
“procStartAbsTime” : 9067169948,
“procExitAbsTime” : 9142077506,
“procName” : “Fritzing”,
“procPath” : “/Applications/Fritzing.app/Contents/MacOS/Fritzing”,
“bundleInfo” : {“CFBundleShortVersionString”:“1.0.0”,“CFBundleVersion”:“353be4”,“CFBundleIdentifier”:“org.fritzing.Fritzing”},
“storeInfo” : {“deviceIdentifierForVendor”:“D2A8EA88-0EA7-5D4B-93C2-1B46D0CCD2E8”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “org.fritzing.Fritzing”,
“crashReporterKey” : “9A0825E9-DE47-6FA4-CAC0-198185AEBC25”,
“codeSigningID” : “org.fritzing.Fritzing”,
“codeSigningTeamID” : “YNHU8667XW”,
“codeSigningFlags” : 570503953,
“codeSigningValidationCategory” : 6,
“codeSigningTrustLevel” : 0,
“sip” : “enabled”,
“exception” : {“codes”:“0x0000000000000000, 0x0000000000000000”,“rawCodes”:[0,0],“type”:“EXC_CRASH”,“signal”:“SIGABRT”},
“termination” : {“namespace”:“ROSETTA”,“flags”:518,“code”:0},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:18563,“threadState”:{“x”:[{“value”:34},{“value”:0},{“value”:140703127843601},{“value”:2048},{“value”:140703127823374},{“value”:0},{“value”:44},{“value”:0},{“value”:140703127883776},{“value”:0},{“value”:4294966996},{“value”:16},{“value”:120},{“value”:30},{“value”:140703127787904},{“value”:140703127886004,“symbolLocation”:12,“symbol”:“crashreporter_info”},{“value”:521},{“value”:13060512487},{“value”:13060513963},{“value”:140703127843601},{“value”:140703127843601},{“value”:99},{“value”:140703127821791},{“value”:13060512784},{“value”:4499243744},{“value”:584},{“value”:9},{“value”:8651882496,“symbolLocation”:0,“symbol”:“dyld_all_image_infos”},{“value”:1}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:140703127763992},“cpsr”:{“value”:1073745920},“fp”:{“value”:13060512672},“sp”:{“value”:13060512640},“esr”:{“value”:1442840704,“description”:" Address size fault"},“pc”:{“value”:140703127659844,“matchesCrashFrame”:1},“far”:{“value”:0}},“frames”:[{“imageOffset”:17732,“imageIndex”:1}]}],
“usedImages” : [
“source” : “P”,
“arch” : “x86_64”,
“base” : 8651194368,
“size” : 638976,
“uuid” : “3df96f32-b9c9-3566-a6b7-4daebc6d6563”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “arm64”,
“base” : 140703127642112,
“size” : 196608,
“uuid” : “15ccd9bf-9a15-3540-a1ff-3abea3e2ca9d”,
“path” : “/usr/libexec/rosetta/runtime”,
“name” : “runtime”
“vmSummary” : “ReadOnly portion of Libraries: Total=1168K resident=0K(0%) swapped_out_or_unallocated=1168K(100%)\nWritable regions: Total=136.2M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=136.2M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nRosetta Generic 8K 2 \nRosetta IndirectBranch (reserved) 32K 1 reserved VM address space (unallocated)\nRosetta JIT 128.0M 1 \nSTACK GUARD 56.0M 1 \nStack 8176K 1 \nVM_ALLOCATE (reserved) 200K 4 reserved VM address space (unallocated)\n__DATA 80K 3 \n__DATA_CONST 32K 1 \n__DATA_DIRTY 16K 1 \n__LINKEDIT 368K 4 \n__TEXT 816K 2 \nmapped file 22.9M 10 \n=========== ======= ======= \nTOTAL 216.4M 31 \nTOTAL, minus reserved VM space 216.2M 31 \n”,
“legacyInfo” : {
“threadTriggered” : {
“logWritingSignature” : “688a19c16328f596b1e3e85910df1080cee36ebf”,
“trialInfo” : {
“rollouts” : [
“rolloutId” : “6297d96be2c9387df974efa4”,
“factorPackIds” : {
  "deploymentId" : 240000014
  "rolloutId" : "5ffde50ce2aacd000d47a95f",
  "factorPackIds" : {
  "deploymentId" : 240000348
“experiments” : [
“reportNotes” : [
“dyld_process_snapshot_get_shared_cache failed”
Model: MacBookPro18,1, BootROM 10151.1.1, proc 10:8:2 processors, 16 GB, SMC
Graphics: Apple M1 Pro, Apple M1 Pro, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Display: S27E310, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Memory Module: LPDDR5, Samsung
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: May 27 2023 01:34:59 version 20.96.31.0.8.7.148 FWID 01-126f2c4c
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB2.0 Hub
USB Device: DeskJet 2700 series
USB Device: Gaming Mouse G400
USB Device: ArmorATD
Thunderbolt Bus: MacBook Pro, Apple Inc.
Fritzing 1.1 (also tried 1.0) and Ventura 13.6.1
Thank you!
-Erin
You are best to make this report on github here:
I don’t see anything currently open on MacOS but I remember something about one of the versions having problems recently. The developers pay most attention to github and only read the forums sometimes.
Thank you. After doing more research I fixed the problem by reinstalling Rosetta via Terminal. Now Fritzing (as well as a number of other apps) are launching again.
