I never use px in INK and always set it to mm or inch at the start. And I don’t have a chance with code. Whatever it did was internal in INK.
It’s the same drawing in both, just one where I manually resized the page to cut through the centre of strokes, the other I resized the page to the drawing, ie, the max outside of drawing.
Here is the link of the 2 drawings -
Pin assignment was inside FZ Edit. It doesn’t matter if the part has connector#terminal in the svg or not, it does the same either way.
page size.fzz (28.8 KB)
EDIT
I really don’t understand how I’m drawing it wrong, when literally this is the only way to draw a rectangle and 100 lines in INK.
Here is a vid of how I did it, if you can point out what is wrong.
*Video deleted because it was updated, so I’m removing this from my YT channel *
I don’t know what is up with that, but if I get the svg from inside FZ Edit/show in folder, it gives me the correct drawing. But if I select File/Export/Image/svg I get blank svgs.
