Fritzing part for Mini DC-DC Boost Step Up Converter 3.7V to 5V / 8V/ 9V / 12V
I appreciate your help getting the Fritzing library part for: Mini DC-DC Boost Step Up Converter 3.7V to 5V / 8V/ 9V / 12V. This module is characterized by the 3R3 inductor and is implemented on dark PCB.https://www.amazon.com/ANMBEST-10PCS-Module-Indicator-Electronic/dp/B091CRCZ65/ref=sr_1_1?keywords=Mini+DC-DC+Boost+Step+Up+Converter+3.7V+to+5V+%2F+8V%2F+9V+%2F+12V&qid=1676487379&sr=8-1
It depends if you need pcb to be accurate or not. There are a variety of converter parts already available (a search in the forum for “step up converter” will find them) most of which are 4 pins as this module. Their pcb and/or breadboard won’t be identical but electrically they are. If you need the pcb view to be accurate one of us will need to make a custom part.
Well the project is finalized and I just need to document the circuitry. So, it has to be that module for accuracy. Unfortunately, the parts available do not match.
mini-boost-module.fzpz (10.4 KB)
Brilliant, Thank you a lot.
