Does anyone have the LoRaWan Radioenge part for fritzing? All info and diagrams can be found here: [ Manual_LoRaWAN_jul_2023.pdf (radioenge.com.br)]. Thanks in advance!
These two parts should do what you want. For through hole use (such as on the breadboard) use the tht part. To solder the part to a board use the smd part. The RF pads don’t appear in pcb in the tht part and the jtag pads don’t appear in pcb on the smd part.
LoRawan-Radioenge-tht.fzpz (21.9 KB)
LoRawan-Radioenge-smd.fzpz (21.8 KB)
Thank you so much Peter!
