Fritzing Part for FireBeetle esp32-E
Anyone knows where I can find a fritzing part for the dfrobot fire-beetle ESP32-E
microcontroller (https://www.dfrobot.com/product-2195.html)?
This should do what you want. Note it appears that SCL and SDA appear (with different names!) on both sides of the board. I assumed they are the same pins and bused them together. That may or may not be correct (there is little useful documentation on this board!)
FireBeetle-ESP32-E.fzpz (25.2 KB)
Scrolling down on the original html linked page shows “Figure 2 Pinout”. That shows the connected wroom pins in orange, with function labels beside them. So 22 SCL and 21 SDA are on both edges, and yes they should be bused.
thanks for the awesome information.
Someone asked for an SMD version so here one is.
FireBeetle-ESP32-E-smd.fzpz (25.1 KB)
Note this is an SMD part (with pads only on the top so you can put one on the top of the board and another on the bottom of the board if you want.)
thanks my issue has been fixed.
@admin can this two post from alex… be treated as spam and be deleted
