Is there a Fritzing part for an Adafruit 367 push button switch? I have not been able to find one including a search within the Adafruit Fritzing Part Library.
you may need to check the hole size for the pins though (the easiest way to do that is to export the pcb as a gerber and look at the hole size in the gerber drill.txt file. )
