Fritzing Part for 3S 10A BMS
Hi @vanepp ,
Pls, provide me with Fritzing Part for 3S 10A BMS…
I will be very thankful to you for this
Regards
Sumit Bhardwaj
In general a google search of the form “fritzing part 3S 10A BMS” will find any part that exists. There is one here:
If this won’t do you would need to provide a data sheet of the unit you want.
But that’s 3S 20A BMS whereas I need 3S 10A BMS
Unless the module is different (in which case we would need a data sheet or web site to make a new part.) that will make no difference. Fritzing doesn’t care about current, only connections and physical size.
