why i can’t open the fritzing app, stuck at 13% can someone help me? app version (.0.9.3b) Windows 11.
First 0.9.3b is some 6 years old now, the current version is 0.9.10 and you would be better to upgrade to it. That said the likely answer is that you interrupted Fritzing before it finished updating the parts repo and corrupted the user directortories. This will fix that (then you need to wait while Fritzing updates the parts repository and don’t close it before it finishes!)
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
~/.config/Fritzing
thank you for answering my question.
it was my own mistake, in c:\Users\username\My Documents\Fritzing
it synced with my one drive, and before that i did a reinstall on the computer so,
when the computer was turned on and I took the initiative to synchronize the my_parts file it couldn’t be opened, when I deleted (my_parts) and reinstalled the application again it turned out to be open.
now i use app version 0.9.10
That is a far better bet. -0.9.3b is from 2016 and development had died. 0.9.10 is recent and has a lot of bug fixes (and automatic parts update has been disabled so it no longer causes problems!) I expect you will be a lot better off with 0.9.10.
