Adafruit Parts Bin: Added dedicated parts bin with 83 Adafruit components including sensors, displays, breakout boards, and development modules.
Generic IC Improvements: Added multiline label support with improved font system (Noto Sans + OCR-Fritzing-mono), standardized pin spacing to 1 unit in schematic view, and enhanced text wrapping that respects spaces, newlines, and non-breaking spaces (U+00A0 and U+202F).
Performance: Implemented optimizations for smoother interactions and faster load times, especially noticeable with complex multi-board projects and large parts databases.
Ground Fill: Added warnings when ground fill cannot connect due to missing paths. Improved ground fill split detection with better warnings.
Export: Improved Gerber export now enabled by default. Fixed IPC netlist issues with buses. Fixed PNP export random ordering.
Hide obsolete parts in search results.
Always bundle contrib folder parts with sketches to ensure completeness when sharing.
Bug Fixes
Fixed ground fill adding shorts across power supplies.
Fixed parts palette going missing in certain scenarios.
Fixed straightening lines being disabled in schematic view.
Resolved error messages being too large to close.
Improved center-to-screen (Ctrl+0) functionality.
Fixed dark mode font color inconsistencies in upload screen.
Fixed splash screen vanishing when clicked on Windows.
Improved metadata editor with proper labels.
Fixed incorrect version display from 1.0.5.
Corrected selection behavior - selecting parts with selection squares now properly focuses them in the inspector.
Fixed regenerate parts database not clearing search cache.
Improved SVG text element handling for dy attributes.
Resolved issues with off-grid component movement on PCB view.
