Freenove ESP32-S3 and Breakout Board
Hi - we’re developing some training materials around the Freenove ESP32-S3 Wroom board and the matching Freenove Breakout Board, which supplies LED port readouts, screw terminals and higher power output for motor control, etc. It is intended to match a 4D Systems Reptor-250 touchscreen display and controller for rapid prototyping of bioinstrumentation and other things.
This is part of the Biomaker training effort at the University of Cambridge (https://www.biomaker.org). We’re looking for any help with Fritzing parts that would allows to make better training materials - all open source. (Similar to: Document-your-project — Biomaker.org, and can be seen in the Biomaker Handbook online)
The relevant processor board and breakout board are:
  1. Freenove ESP32-S3 Wroom board, with:
  2. Freenove ESP32/ESP32-S3 Breakout Board
Previous work, similar parts
The Freenove ESP32-S3 Wroom board is similar to:
ESP32-S3-1-N16R8-module (ESP32-S3 CAM development board WiFi Bluetooth module onboard ESP32-S3-1 N16R8 module dual TYPE-C interface.) by Peter Van Epp (vanepp in forums) (ESP32-S3 CAM papan pengembangan modul WiFi Bluetooth onboard ESP32-S3-1 modul N16R8 antarmuka TYPE-C ganda - AliExpress 44)
The Expressif chip is slightly smaller on the Freenove board than that shown on this existing part.
There doesn’t appear to be an existing part for the Freenove ESP32/ESP32-S3 Breakout Board.
[ x] Breakout board, sub assembly, plug in module (A)
Thanks in advance for any advice or help with this. Best regards, Jim Haseloff.
Here is the Freenove ESP32-S3 Wroom board (it is a relatively minor edit of the ESP32-S3-1-N16R8-module)
ESP32-S3-Wroom-board-Freenove.fzpz (30.6 KB)
the breakout board will likely take a while longer
Dear Peter,
Thank you for this - it will be very helpful for our training efforts, and is much appreciated!
This is a super-helpful community.
Thanks again, Jim.
Here is the breakout board. It is a bit more complex as it is designed to take the cpu board as a daughter card which implies some limitations. The basic part looks like this
drag the cpu board in to the sketch
then move it til it aligns (if it aligns, more on that later!) to the female headers where it goes in real life.You need to move the cpu card on to the breakout board to get it to connect (the circled in green green connections) moving the breakout board won’t make the connections (a Fritzing quirk.)
the wrinkle is that the female headers are offset 0.05in in x from the rest of the pins so sometimes the pins will be correct (as here) and it will connect, and other times (depending in what Fritzing took as the reference pin for the grid which changes from load to load at apparent random) it will be misaligned and won’t connect. The fix for that is to change the grid size from 0.1in (the default) to 0.05in which will allow the board to connect.
which will look like this if the default is set (it is stored with the sketch so it will stay once changed)
to this
then you should be able to move the cpu board to connect. Which will produce this (the cpu board is placed randomly in schematic so it won’t align)
drag it in to position
and click on the ratsnest lines to make the connections between the breakout board and the cpu board and it should match real life.
edit: Nov 2025
Correct a typo in breadboard (won’t affect part operation at all but please upgrade if you have downloaded this part!)
esp32-breakout-board-Freenove.fzpz (61.0 KB)
Now I will move on to finishing the display board part.
Thank you Peter!
(Is this what you call waiting? - that was super fast)
Much appreciated, Jim.
I believe the 2 labels need to be switched
Indeed that appears to be a typ0. While looking at that I see the various jpegs I have show different connector names, am I correct in assuming other than the flipped label the board is correct?
I have replaced the part with a corrected version on the assumption that was the only mistake.
Hi. I’m not of any other mistakes - thank you for quick fix.
