Hello everyone,
I found this RS232-to-TTL converter component, but I see that instead of having the VCC, RX, TX, and GND pins, it has the DB9 connector pins. I’m not sure if it’s possible to modify or fix it so it matches the correct pin layout.
RS232_Shield.fzpz (10.0 KB)
Thanks in advance!
