please can you make this relay socket? 95.13.2
Thank you.
This part should do what you want. Note the mounting hole is not drilled by default, so if you want the mounting hole you need to drag a hole (and size it correctly!) in to your sketch. Checking the pin placement would be a good bet too, I assume their copper side view comment is correct and reversed the part (as Fritzing is looking from the top) but that may not be correct.
finder-95-13-2.fzpz (4.0 KB)
